So, I'm buying the phone in a couple of weeks and I was thinking about the battery. So, how long will this last with this type of use?
- Auto sync
Always off
- Data connection (something like that)
Always off
- Internet browsing with Wi-Fi
30 mins a day (at most)
- 45 mins of playing games (at most)
- 20 mins talk and messaging time
- 10 mins music listening
- 15 mins of photographing (at most and occasionally)
- Standard wallpaper
- Default brightness settings but brightness set to Power Save
- Removal off all (internet requiring or not) widgets except the central home screen widgets and maybe the weather widget
Hi HeadshotGuy, The Above posted things are likely matching to my daily usage
For me The back up is Nearly 24Hrs...and some times more than that..
trust me 1 day guaranteed, depends on the kinda games you play though, a HD game will defnetly take it's toll on the battery otherwise lasts more than a day
So the battery backup isn't really a problem, is it? Anyway if it isn't a big trouble, I heard the P has a load of pre-instsalled apps. You you mind telling me which are they and what to definately keep?
Thanks
Thanks for the reply itskiran2000. So I guess the battery backup isn't really a problem at all since the best smartphone in terms of battery lasts about 2 1/2 days.
Welcome Headshotguy, Yeah you'r gonna have to charge it once in a day, if you think you can live with that go buy it, and what smart phone are you referring to here btw? a moto driod razar maxx ?
Yeah, That's it. Sorry for the late reply.
