Hi i am trying to remove a password lock on my sony xperia miro, i have been told to download sony software but because the phone wont unlock the screen the software wont recognise the phone, i have also tried the power button and volume down button together to reboot but that doesnt work either,,,,any help at all or suggestion's would be really appreciated.
Switch off your phone and unplug from Pc
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
If you have updated since you bought it then it won't go back to that time - it will only return back to the firmware update when it was installed
