Hi guys,
I think theres some problem in the loud speaker of my phone. I think its not as loud as it used to be. I went to the service center and they said the speakers are fine. I even did the service menu check with my speakers and i could hear everything. But i still dont know if my mini pro is as loud as the other mini pros. Theres this song in my phone which i cant hear properly. The songs link is - http://www.4shared.com/mp3/OT1U_IWz/07_Ari_Ari.html?
At around 0:08 a guy says something but I cant hear that on my phone, i mean i can hear it but the sound is too low. And at around 0:20 another tune starts which is also not audible. I can hear that on my laptop and other phones but not on the mini pro. So can you please put that song on your mini pro and see if you can hear it?
Thanks alot,
Adi
I feel that you are joking
Maybe someone is say something in the track. I dont hear that. Also if I could hear something , I dont understand that language. Check some other tracks, because this track has almost all instrumental and no words in there. But I think that if the service center said that the speaker is ok, then is most likely that is nothing wrong with it. Im sure that they done some kind of tests.
Alright, thanks mate!
