I've just upgraded my phone's software as suggested by my pc companion. I'm just wondering about the specific changes made aside from those found here http://www.sonyericsson.com/cws/support/mobilephones/start/xperia-mini-pro?cc=ph&lc=en, if there are. After updating my phone software, I noticed the screen lock animation has changed. It performs a black out and fade like effect, previous animation before I updated the software was the "switch off TV-like" animation. Just wanna know if thats normal. Thanks
Oh I see, but whyyyy
Are there any other changes?
Thanks uliwooly-wooly btw
well we have the panoramic and 3D panoramic options
I was wondering if SE has some kind of list regarding all the changes.
Checkboxes when adding message recipients were also added. Didnt see this on the previous software
that was included with the last update
