Hello there
I'm having a really annoyig problem with my phone, the only problem i have, but it's driving me crazy. So, after I updated the software to 2.3.4, a small blue facebook icon appeared on my status bar, saying: Unabla to sync facebook, or something like that, in hungarian. When I delete this from the status bar, it appears again in seconds, even when I'm on wifi or 3g, and using facebook. So it' driving me crazy, can't meka it go away, and nothing seems to help. In the settings menu, at sync settings, my emails and the facebook are synchronised, but facebook inside xperia is not, and there is a green circle next to the others, but this one has red circle and saying there were problems with the sync, it's gonna continue later. Manually starting the sync does not help.
Any other ideas? Or is it just because the facebook inside xperia app is not updated yet?
sometimes these stuff hppen.
ok go to settings > applications > manage applications > all
find facebook , clear data and all..
log in again with your facebook id.. also turn on your facebook inside xperia
it wont show again..
Hi, see if this helps ....
Goto Settings>Sony Ericsson>Facebook inside Xperia, play with those options.
go to setings > accounts and sync > turn off data sync ( facebook account )
Thanks, but only turning off the facebook inside xperia helps. And why do I have to turn this off, that's not what I'm paying for...
Thanks man, seems to work fine!
hmm
mark the helpful and correct answes
