Hello, I have Sony Xperia J and i upgraded it to 4.1.2 JB . I want to downgrade it to 4.0.4 ICS because of problems. How can i do it without losing system apps (like Smart Connect). P.S sorry for language mistakes. I don`t know english at all.
Do i have to have root, unlocked bootloader, or something like that? If yes tell me how to do this because i don`t know.
To flash another firmware,you do not have to root.
does simlock will return while doing this?
do i have to unlock bootloader?
No,it should not return and you do not have to unlock bootloader.
thanks a lot i`ll do this. Can you give me a link to this file?
11.0.A.7.5 (ICS) Stock ftf`s - Is that one is good?
