I just bought an Xperia go st27i, in gingerbread it was all ok, very smooth and fast, but once i upgraded to ICS..
When i run any app, its like in 0.5x slow motion, even flappy birs wich is very light graphics app is slow as **bleep**..
Scrolling is also in slow motion and the lock sound is delayed..
I tryed to do factory resen, didnt help.
Any ideas?
Anyway i resolved the problem by rootimg my phone and then setting my Cpu speed by setcpu..
Now it runs fast as **bleep** all the times.
Hi Qone
>please check out the Ram usage on you phone,
>settings -> apps -> running
>you might find available/Used Ram usage, if you have less then it mean to have lagged behind, so to fix
>make sure in settings -> apps -> running -> remove background app which you are no longer using it, make some more Ram storage, then try to do what ever you want, this might fix your issue
>if you are using Chrome app on phone then remove the app, restart the phone and try it again
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
I have about 170 MB of free ram.. Chrome is disabld.
