Hi, so umm, recently my phone's headphone jack cover/lid became loose and now whenever I plug in my headphones to listen to music the sound comes from internal speakers. I have to press the jack as hard as I could just to listen to music with my headphones and whenever I try to put my phone in my pocket, the music pauses, I press the play button again but this time, the sound comes from the internal speakers. Is there anything to do in order to solve such problem? Please, don't tell me to contact Sony, because there isn't any Sony service centers where I live (Qatar)
repair your phone with either PCC or SUS, if that doesn't work then most likely its a hardware issue.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
@uliwooly actually, I think it doesn't have anything to do with the Android software. I mean, whenever i turn my headphone jack either clockwise or counterclockwise, the music stops playing. I press the play button again but the sound comes from the speakers not from the headphones. It's been like this since the headphone lid/door became loose and won't close. I really I hope someone could help me. I don't wanna buy a new phone since I'm broke at the moment
that's why I said if neither SUS or PCC work then it will show that its a hardware problem.
have you gotten your phone wet at all? check the flaps for a white rectangle if its pink or red then there's water damage.
Yeah, I can see a white rectangle. It's the one made of rubber/silicon right? I can see a very small hole. And no, I believe I never got it wet. It was in my pocket and I wasn't using it for about 5 hours straight
the water damage indicator its quite small
Something very similar happened to me as well lately... Basically, since that rubber band that seals the cover got lost somehow, not only I can't close the cover properly now, but everytime I want to listen to some music and the my headphones' jack gets pulled out just a tiny little bit, the music either stops or switches to internal speakers. And it drives me freakin' nuts because it really isn't that hard to get that jack plug moved out of place even a little bit. And yes, to get it back, I have to push it quite hard back.
