I am having a strange problem with my Xperia Arc S. It's keep auto-restarting all the time and does not start at all. It's showing the "Sony" Logo then the "Xperia" logo then blank screen and then after some waiting it's keep showing the "Sony" logo and "Xperia" Logo. I reported this to Xperia Care and I got advice to visit Sony mobile Service Center.
After I visited the service center, the technician agreed to repair the Phone provided I give them a formal declaration that during repair if anything goes wrong, then I would not hold them responsible for the damage as the components required to rectify possible damage is not available with Sony.
Please advice me what to do. Is there really any possibility for unrecoverable damage? Do technicians in service centers can claim such declaration?
Make sure your phone has at least 50% battery and turn it off.Connect the usb to your phone,holding volume down.
Ohh..great ..! the solution works ..and i got my phone back... thanks a lot!
Dear s,
My phone rooted but auto restart problem ,when i go to update centure his says softwere editted or correpted.
pc compasion also say like that.
plz help me
Hi ...
I had a same problem and its resolved by just some working mentioned below, do not panic your data is same and it will be recovered, t
when your mobile arc s is continuesly restarting, when xperia logo is displayed, long press the home key or continuesly press it, the middle button and in 4 to 5 restart you will see the lock screen and your wall paper and it might restart from that point also but try again and again and if the screen stays move quickly to settings and close the blue tooth and with the next restart your phone will be normal, hence forth do not use bluetooth i future
It will require many try so be patient and try again and again.
I was successful twice and got all my data as it is.
@ashok.gos wrote:I am having a strange problem with my Xperia Arc S. It's keep auto-restarting all the time and does not start at all. It's showing the "Sony" Logo then the "Xperia" logo then blank screen and then after some waiting it's keep showing the "Sony" logo and "Xperia" Logo. I reported this to Xperia Care and I got advice to visit Sony mobile Service Center.
i m having the same prblm...i followed the steps told by u bt it didn't worked at all....m doing the same frm the last 1 hour
pls help me
I've tried the solution and the wallpaper but too fast but thanks alot I think it wil work.
Hi Guys,
I had same prob but it shows an Error while comes to update....
It says an ERROR occured in PC comp it is unable to repaire my device.
And it shows USB Debugging was OFF. So unable to continue.....
Please help out with detailed steps to follow to get my device back to work
Thanks in Advance
