I updated my 'arc' via PCC. Everything was ok but after tested it and some problems with games I tried to downgrade with flashtool 0.7.0.0. It was successful too but after rooted it I realized some programs were still in
system/vendor/app.. U know normally in GB all is in system/app.
How to fix this ?
This could happen if you marked the ticks incorrectly
Check the downgrading here
I'm not sure on how to fix this so I suggest that check over at the XDA forums.
