I unlocked my X10a using a software from cellunlocker.net, but now it won't connect to any network. It says my SIM won't allow connection to this network. Also, when the phone is turned on, it asks for the SIM to be inserted, although it is already in. Finally, it says SIM card is locked and asks for SIM PIN to unlock, but I never had SIM PIN nor my network carrier. Unknown SIM PIN and SIM locked phone... Any suggestions?
do you have a SIM card pin lock? just get a brand new SIM card and try again.
I tried a new SIM card but same problem.
My trouble started when I got my phone unlocked using the software from www.cellunlocker.net.
I've used that website before w/o any problems, you should contact them as your phone might still be locked to that carrier/network
They tried to help but ended up giving up and gave me a refund, with the broken phone...
repair it with SUS or PCC and check again
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Hai, Your phone is still locked. Not unlocked. I think the software method did not unlock your phone. Unlock Code method is better than software method. There fore you can use unlock code to unlock your phone easily. If you want to get pin unlock code you can visit this site Classicunlocking.com . They will help you to unlock your Sony X10a mobile and they will send the code to your mail shortly.
