I know the Sony Ericsson Live is supposed to have 320 MB of internal storage, but according to the attached screenshot, mine has 420 MB... Has anyone else seen this? Is this a software error (I have the latest firmware installed, but I was seeing this even before I updated my phone software to version 4.0.2.A.0.62) or does the phone indeed have 420 MB? (if that's the case, thanks Sony Ericsson! :smileywink:)
internal memory "UP TO" so it varies from regions/firmware versions, the more preloaded crapware/bloatware/pre-installed apps the less internal memory.
regarding RAM
check this thread
Well, I think this settles it - I just installed AVG on my phone and it also says there are 420 MB of internal memory in it:
Do all the WT19i phones come with 420 MB instead of 320 MB?
My phone too shows 420MB as the total space. Well am still on the old version of software only :smileyinfo:
that's right and also i don't found actual ram size which is 512 mb....:(
can anyone tell me why is it so....????
regarding RAM
check this thread
Thank you very much for the link - this was actually going to be my next search on this forum, regarding the amount of RAM.
Yeah it's displaying 420 MB of memory in my phone too..! i have upgraded to version 4.0.2.A.0.62 released by SE in india... can anybody tell me what other features/improvements/ does this firmware update have? I mean why exactly one should update to version 4.0.2.A.0.62???:smileysilly:
