Dears
have a big problem can't connect to wifi after update my phone wifi key not active please help
Thanks alexdon the problem was the wireless bottom was not active at all I already solve this problem by restore my phone to default
Go to settings-wifi and activate it like that.Or it cannot be activated like that?
It is ok man,I am glad you managed to sort it out.
same problem on my xperia z
saved wireless profiles "not in range" but resrtart phone again connected
