Hiya all
Searched round and can't seem to locate a solution to my problem.
Updated to ICS 4.0.4 (4.1.B.0.431) night before last and pc no longer recognises the phone.
Have tried :
- d/load & reinstall of PC Companion
- restart/reconnect of both PC & Phone
- Sony Software update (advises software is up to date)
- unmount of SD Card
- mutilple searches of Google for some form of driver/forum entry
Most likely there's something completely simple I've missed, but if someone has an idea for a fix would be greatly appreciated.
Thanks in advance!
that's insane
lets try something else, create a new administrator account on your pc -> install sus -> restart your PC and see if it now recognize your phone
connect your phone -> control panel -> add a device -> make sure your firewall and antivirus is off
Hiya Uli, thanks for responding!
Reconnected and tried add new device (no firewall or antivirus active), phone not coming up.
However "Xperia" does appear under Devices and Printers with an ! indicating code 28 "driver not installed"
Device is being recognised as "LT18a"
Have tried troubleshooting to retreive the driver, but result is is none found (online or locally).
Have tried removing this device and reconnecting the cable, same result.
ok repair your phone with SUS or PCC that will download the needed drivers
OK run a repair thru SUS and gone thru initial setup on the phone
Reconnected to PC and same issue - LT18a : No driver found
PCC does not see the phone at all.
Still appearing in Devices as Xperia with the !
Driving me nuts!! lol
Yes, you're brilliant!
Did as instructed, but also removed old SUS & PCC - then set the phone to install PCC on connection
Initially after new account, reinstall SUS, there was no change - but troubleshoot from Device & Printers seemed to kick it across the line 😃
Thankyou very much Uli!
I know I'm AWESOME!!!
