Bug #1: Empty/Missing Album
Bug #2: Camera Lag
Bug #3: 3D Camera Missing
Bug #4: Stamina Mode not working at all
Is there any firmware on the works fo fix these bug issues? Let us know.... Be considerate Sony....
I think we must make a petition to Sony to fix all known bugs on Jellybean Firmware. We are spending money on their products so they have to make some actions on these issues...
there are myriad threads on this topic, please post there. where? use the search bar (Top right corner)
settings > apps > all > album > clear everything > restart your phone
repeat the same for the camera
search the forum
it does work but you have to read about "Stamina Mode" search it out
try to factory reset after you update you HH to JB. It help me for some trouble above.
@uliwooly settings > apps > all > album > clear everything > restart your phone> it works for a while but these bug comes back after a while.... clearing album cache is good solution but we need a need permanent fix for these bug...
@maoels> Been there...Done that... The bug always come back....
