Hi
I just upgrade my X10 mini to Android 2.1 and after that I can't connect to WiFi anymore .
every time I try get this error message : "Unable to scan for networks" !!
there was no such problem before and I easily connect to my wireless adsl router with my phone running android 1.6
anyone can help me?
thanks in advance
Hello, I would try re installing the update just incase something didn't go right.
thanks
I do reinstalling the upgrade and it solved my problem
