Hello fellow SP users I want to ask that does wifi remain active even when we activate "Stamina Mode" if we've set wifi settings to "Keep WIFI on during sleep to Always"..?
ok so it means the apps which I'd add to the exception list will keep working normally with wifi even in stamina mode irrespective of whether the screen would be on or off..
Stamina mode will not disable wifi,low battery mode will.
Oh,I think yes.The battery savers overrun the wifi settings.
I think no..it just dont let the apps to connect to network for more battery life...as you now it dont effect on download and upload or choosen apps
Yes,it should be like that.
