Is there any headway on finding a solution for this? Seems like reverting isn't working for some. Are they fixing all this messiness
in the next upgrade? Sending out a fix? Stopping support for lt30p ' s?
It worked.The xperia has 4.3 and was experiencing the 'association rejected' problem. Turning Bluetooth off fixed it
Before resetting your phone to factory defaults, try resetting your modem settings. Assign a new SSID and save changes. Now on your phone go to settings > wi-fi > refresh / scan for your network. Connect . It should work now.
if not, try resetting your phone to factory settings. Don't forget to wipe off your internal storage. After Rebooting the device, follow the above procedure.
good luck.
Same here, on a Sony Xperia XA (F3111) with Android 7. I have to turn off Bluetooth to have WiFi.
