I experienced in android 4.3, the wifi never sleep, even after the screen is off, the wifi still runing.
The screen mirroring became worst than before update. Screen mirroring is almost useless. When I try to connect to the other device (ex PTV 3000) after a few seconds the screen mirroring turn off in the phone. In 4.1 worked somehow, now fail. Please Sony do something with this.
No success!
Wifi still keeps dropping!
I suggest you download sony update service and repair your device:
http://www.sonymobile.com/gb/tools/update-service/
already done. No luck.
Thanks. Problem 1 resolved.
There are so many bugs in Android 4.3 . I have upgraded my TX recently and i am very disappointed.
1. When call is received, cannot hear the opposite person and call gets disconnected suddenly
2. When there is a call, the Drag facility doesnt work properly
3. Performance is also not good
Except the Sony Update Service isn't compatible with the Sony Xperia T
Of course it is.You need to run SUS in compatibility mode with windows 7.
