My phone died a few days ago, and since then i've tried to charge it, Didn't work, Plugged it in usb, Still doesnt work. Wondered if anyone know why? Thanks
Then you should be able to get it repaired under the warranty.
Well if you can't charge it up, then you need to take it to a service centre.But if it's still got some charge left, you can always try running the SE update service on it and see if that reactivates your phone.
Well without sounding stupid, what's a service centre?
A place where they service/repair mobile phones.
Wouldn't it be easier to just send it back?
You mean send it back to wherever you bought it from, so they can repair or replace it, depending on the terms and conditions under which the phone was bought.Is it still under warranty? How long ago did you buy it?
Got it just over 3 months ago, from a catolog.
