Hi There,
The notification tone in WhatsApp is suddenly not working. I have tried everything.
1. Factory Data Reset
2. Uninstall/Install WhatsApp
3. Manually setting tone.
But nothing worked. Anyone having the same problem. It started today only. For 2 days it worked well.
The application developer will tend to roll out an update to address this issue with their app in these cases.
What are your thoughts about this forum? Let us know by doing this short survey.
I am on JB btw...
having same problem.. worked fine about 4 days ago. thought my notification light was dead, but it works well with other applications... just not working with whatsapp.
its probably a whatsapp compatibility issue.
Thanks uliwooly... Surprisingly it's started working now.. :smileyhappy:...
Similar problem with imo messenger and notification LED. Doesnt work anymore with JB.
Hi Sam,
Thanks for the response. So are you saying that it's WhatsApp at fault and not the SONY JB update???
Regards
Sagar
I'm using whatsapp2.9.6338 and Z 10.1.A.1.434, already set on STAMIMA enable the Whatsapp, but still no LED notification.
Well, After doing a factory reset its working for me for the last 5 days. Lets see....
