There is a small button located on the wright top? (not the one beside the on/off button)
the front facing camera or light sensor
1. Notification LED/Battery status 2. Proximity sensor 1 3. Proximity sensor 2 4. Ear speaker 5. Front camera 6. Light sensor 7. Touch screen 8. Menu key 9. Home key 10. Back key | 11. Keyboard 12. Power key/Screen lock 13. Connector for charger/Micro USB cable 14. Headset connector 15. Camera LED light 16. Camera lens 17. Volume key/Zoom key 18. Camera key 19. Speaker 20. Strap hole |
It's the noise-cancellation microphone, used to cancel background noise during phone calls.
thanks guys,please check the attached photo,I put circle around the hole!
hi @szeze as mentioned by @uliwooly and @degraaff it is the second microphone used for noise cancellation during call...
Oh, clear answer, thanks guys.
Done :smileygrin:
haha..:D thanks!!
