Hello...
I have a Sony Ericsson Neo V...for a week or so , has installed itself on my mobile this application
https://play.google.com/store/apps/details?id=com.google.android.gms
could someone tell me what it is?
Also if i delete , after closing and opening the mobile, it's into the applications....
Sorry for my english...
go to
settings > apps > all > look for it > disable, you can also disable apps and/or ad ons that you dont use (like timescape or fb integration apps)
unrelated topic, if you have some time please check this thread
it's an adon for Google+ you can disable it
how can i disable it?
go to
I can not do it in this application .....
I can only remove ..... but reappears after opening the mobile ...
you have no idea what's happening?
is useful for mobile?
if you can uninstall it, then that's even better, uninstall it
dude this is easy ... but when I turn on my phone again, is installed inside again ....
open the Play Store > menu > my apps > google + check if its allowed to automatically update
I have not enabled automatic update.......
