Hey guys can someone help me?
The weather widget in my xperia sp is gone, simply vannished! It stopped working (i touched it and it didn't open, tryed multiple times) so I turned my phone off and on again and then it wasn't where its supposed to be, nor anywhere else...I've seached in the apps list and it's not there, and I can't seen to find a place to donwload it again....
That's a great idea, make sure to backup everything on your phone
Bridge (for Mac)
Alternatives on How to backup Xperias
Have you disabled any app?
No, I didn't. There where some other apps that stopped working too, but the problem was with the shortcurts...I thinks its something relationed with the last android update, but no one else seems to have the problem with the widget...
Any taskillers or antivirus or battery apps?
only the mcafee mobile that came instaled
Uninstall it > restart your phone > check again
nothing, the widget isn't anywhere (though the phone seems faster...) I think I will try backing up and reinstaling the last update again.
Bridge (for Mac)
