Xperia Go is awesume.Just wanted to water-test my phone and the phone passed the test successfully.Droped it in the water bucket and removed it.Water-tracking worked perfect.But when i opened media file(while the phone was wet)the speaker volume was very low even when the media volume was full.When I removed the back case of the cell i noticed some water droplets inside it and on the speaker.I rubbed the water and then the speaker worked perfectly.Anybody has idea from where the water must be leaking inside.Phone is just 3 weeks old.No rough usage of phone or droping the phone on a hard surface.
Solution Anybody...??
There is no solution. Water seeps into the earpiece, speaker and microphone holes, which causes the volume to be low until they dry out. It doesn't seem to cause permanent damage, so it's still water resistant. You just cannot use it underwater.
Per the manual after a soaking in water you are to shake the phone to remove water from earpice/speaker and microphone
thanks for the reply.figured tht out....
