Hello everyone,
Last night I placed my wife's Acro S into her dock on our nightstand, but apparently it did not connected properly, so this morning we woke up to the phone's alarm (luckily) at 1% of battery... and after that the phone turned of before I could quickly place it properly into the dock...
Then immediately after it started charging, the following screen showed up, instead of the normal booting animation (which came later after doing whatever this was supposed to mean)
I managed to take a picture of it with my own Acro S which had charge. This is the first time any of our Xperia has shown this screen and I would like to know what does it mean.
Thanks
It means it is fixing something,you should let it connected to charger until done.
I have same problem with my xperia s. But this repair sign stays for almost 10 minutes and then shows some caution symbol .
