Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I would suggest that you first of all try to clear data for the theme you have selected under settings > apps > tap the theme > clear data. Restart the phone and see if you still experience black screen.
Anytime, glad I could help!
