is sony server really overloaded???coz i cant upgarde my walkman live as evrytime the update stops saying "update error:server overloaded" n its been happening from past 2 days
Try using the Update Service to resolve this issue.
Update Service:
http://www.sonymobile.com/global-en/tools/update-service/
Let me know how you get on.
and at me it lasts a month
Update Service:
tnx 4 the support/
but..
my phone WT19i. offered me to download version - 4.1.B.0.431. Is suitable for me, you proposed revision (archive) 2.12.8.23?
I downloaded your file and I can install.
Sorry, I have not been able to understand the query in full, are you saying you have been able to perform the update with the Update Service.
thanx jake for the link now finally i upgraded my walman live with android 4.0 n its awesome!!!!again thanx a lot
Hi Jake,
Hoe you are doing good. Believe you could help me out in getting this isue that i am having with my Live with walkman wt19i after i upgraded to the latest version android 4. My previous updates that i made to the phone was fine. However after the latest update i seem to have started facing the below issues.. could you please assist in getting it resolved.
camera quality has gone worst
i hear unwanted ringtones while i am making any call to someone until it is received by the other party
phone hangs very often and needs to be restarted.
I had tried to repair using the repair link but it is of no use. Kindly assist
Regards
Shashi
No problem, glad I could help :smileygrin:.
Can you clarify if the the repair was successful or were you unable to perform the actual repair on the device?
In regards to the ringtones heard when calling people, this is a function that networks allow users to have, simply put the person you are calling has added this song for people to hear when you call them.
Thanks for coming back.... Yes i was able to complete the repair procedure but it was not of any much of help... Let me know if you need any further info...!!!
Regards
