Hello! I'm sorry if this issue has been addressed before, but I couldn't find it with the search function...
Anyway, after the new build (6.3.A.1.100) on my Xperia P, it not only did a complete overhaul on the interface design, but it also removed(?) the easy shuffle/repeat menu option when playing music.
That is, it doesn't give me the music options any more when I press the menu button when playing a song. It gives me the option for the clear audio thing and to share the song over wifi...but I just want to select if I want shuffle on or off and if I want to repeat all songs, or just one.
I know I can select "shuffle all tracks" from the song overview, but I liked that little menu function.
Am I missing something, or did they really remove it? If so, I am not pleased. At all.
Help would be greatly appreciated, thanks!
For shuffle or repeat,when a song is playing,tap the screen on the album image for 2-3 seconds,you will get 3 options in the right part of the screen.
You are welcome.
How can I shuffle all my music files?
This option only shuffles the current CD content.
Go to walkman,play a song,tap longer on the album photo,you get 3 options there.One of them is shuffle.
