I want to buy stereo bluetooth headphones. Something like this:
Will this work with the W205? Do I need some kind of special software? I want to be sure that it will play music via bluetooth before I buy the headphones.
Thanks a bunch!
According to your phone's specs, it supports A2DP stereo Bluetooth, which is what you need to use this headset.
Thanks doc!
So I basically connect the headphones with the phone via BT, play the music and I'm all set?
Yes, that should be it.
I am sorry to say that SE W205 does not support most of bluetooth setreo headsets. I tried several, including MW600 and it did not work. I have yet to find one that works with W205.
