I deleted some system apks by accident, and now the highest volume level with headset was limited to about 65%. I want to know which system apk was correspond to the volume level warning? Can I fix this problem by reinstalling the apk? Thanks a lot.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
unrelated topic, if you have some time please check this thread
it'll be easier to repair your phone with SUS
A more question, I install the SUS and connected to my phone, however, it just told that no update was available. What should I do to use the SUS to repair my phone?
that means that ICS it's not available for your SI number just yet.
here is an alternative
http://talk.sonymobile.com/thread/41609
Thanks a lot~
