Hello,
VOIP calling is not at all working after JB update.. I mean am able to install the application, but when called - My voice is not heard to the opposite person and their voice is not heard to me as well.. Tried with 2 applications - Fring and MobileVoip, both got same problem...
Anyone noticed this issue ??? Please help, if its a real bug then its a very critical issue to be fixed...
Well, am doing a software repair now since i updated to JB directly from ICS w/o clearning any data...
Thanks in Advance for any advice given...
Since you haven't posted again, did the software repair fix the problem?
