My videos are taken in protrait mode but playbacks are in landscape mode. When I try to rotate my phone, the video rotates as well. How do I get my protrait mode videos to play back the same way they are taken?
Please help.
download mobo player from the android market and play your video file in that app..
it will work the way you want
Thanks! It works great! However, how do i set it as the default player for my videos?
just click on any video..and it will ask , how to open it.. whether in the video player or mobo player..
tick " remeber this \ set as default" and click on mobo player
now everytime you will play a video..mobo player will launch it..
but if you dont get the option of choosing the video player or the mobo..uninstall the app and re=install it..
then you should have the option..
just in case : if you want to remove it as the default player..
go to settings > applications > manage applications > downloaded
then select mobo player..scroll down and select clear defaults
mark the thread as answered..
