Do i need to install antivirus to safeguard my xperia U ics? If yes then which 1 u have?
Which mobile tools u use for sms/call blocking?
Folder lock?
Memory/ram freeing (cleaning) tool with auto scheduling?
I am not informed in camera apps,but you can search google play for some,try them and see which one suits you best.And yes,do not use antivirus,there are no viruses for android.The virus can be taken from windows files,but it is not sure how it will react.
Never use free RAM apps,antivirus or taskkillers.Try to use the implemented battery savers,close the apps when not using them.
wow that is weird... people keep on screaming about antivirus for their phones. well mine is my 1st android phone so I'm not aware of "Do's & Don'ts" .... I was just seraching online.
So u said: We don't need 3rd party antivirus on my Xperia U...... (Sure?)
Which tool/utility u suggest for taking good photos, bcoz as u know the in-built camera app for the so-called 5MP cam is not more than a basic thing. shows that development team was not paid properly to make this camea support app (in-built).
Please note that I don't want photo enhansers or photo effects, I want to click a great photo with admirable details.
Thx, and yes I was looking into the playstore too for camera apps... there are 35 of them and everybody of them are offering something to edit photos. after installing and uninstalling ew apps I'm (right now) looking into "Camera360" app, it is allowing to take pics and directly save.Other apps were opening "edit" options after taking photo. Obviously I can't take next photo unless that "edit" option goes-off.
Will keep sharing.
Another thing....
Now-a-days almost everybody are releasing their mobile app like: banks, credit cards, mobile networks, movies, online shopping, etc... I have recently disabled call blocker feature in 1 of such app I have. Did anybody here came across the clashing apps? If yes, then can we share names of those apps please?
Glad you found your app.As for the second thing,can you please explain what do you mean by clashing apps?
clashing I mean... Hmmm.... like call/sms blackers, inbuilt battry saver and external apps... like that.
