Hello everyone.
I dont know how to set us ip address in both computer and my phone to use my computer's internet connection by Wi Fi on the phone.
I can connect with my phone by Wi Fi to computer but I can do nothing then. I also shared the internet connection but i cant use it on my phone and the cause is incorrect IP configuration, I think.
I also want to transfer my files on the phone to my computer (and vice versa) by WiFi but I dont know how to do it.
Would u pls hlp me
No. When I select "add a wireless device to the network" option in win 7 it didnt find my device (the WiFi is powered on).
And when use "Manage wireless network" option and add a connection, it would be created and connected to my device (PHONE).
I can not ABSOLUTELY browse the web in my phone (when connected). I have no access to any other wireless network.
Then I suggest you try a (free) wifi hot-spot, when you get the opportunity, to test whether your phone's inability to browse the web while connected to a wifi network, is restricted to your own wifi adapter, or not, as the case may be, so that you know if the problem lies with the phone itself.
Another thing you can try is, if this is possible in your adapter's settings using the PC, is to add your phone's MAC address to the adapter.
Ok. The first idea might be possible for a time. But with regard to the second notion I should say that I already added my device's connection in the adapter settings.
And so?
I'm still waiting for you to test your phone with a different wifi network.
Hi. I rarely access any other network ( IN FACT NEVER ). I've purchased my phone few days ago (NEW). I wonder if it needs unlocking?
You mean unlocking from a network?
I meant FLASHING . . . .
You mean updating/re-installing the software with the SE update service, or with a different version of the software?
No. I already did it. I've read about that matter in some weblog/sites. HACK............. (EDIT: UNLOCKing)
