Somehow the data (userdata mmcblk0p14) partition of my Xperia T has been reduced to 2 GB.(mount point /data).
There seems to be an extra partition 10Gb (SDCard mmcblk0p15) (mount point /mnt/int_storage) but is not used to install apps.
Bootloader is locked,official firmware 9.2.A.1.205.
I've used 'Sony PC companion' to reinstall the latest official firmware.
Didn't resolve the problem.
Please advise. Would like to keep the official firmware.
Jean
Xperia T model LT30p
Locked bootloader
Android 4.3
Build number 9.2.A.1.205
Kernel version 3.4.0-perf-ga3976ea
Total internal memory should be 16GB
Using Diskinfo reveals
Data (Userdata) mmcblk0p14 (/data)[ext4] 2GB
1.8GB used
199MB free
SDCard mmcblk0p15 (/mnt/int_storage)[ext4] 11.1GB
1.1GB used
10.1GB free
That's how its supposed to work, 2GB for apps and the rest for pictures, music, videos.
Check the white paper
http://support.sonymobile.com/global-en/xperiat/supportDocumentation/
Seems you're absolutely right (but you already knew that).
Very disappointing only 2GB out of the 16BG can be used for app's.
Seems I'm forced to abandon the official firmware to get more joy out of this device. (regretabble)
Thanks,
Jean
Not quite, you could root your phone > partition the SD card
