hi,
i am planning to buy the xperia SP, but before that, i would like to know if it supports USB OTG. i will be connecting pen drive, keyboard, or a gamepad (xbox 360 wired controller). can any user confirm that they will work?
i had a problem with OTG cable and usd pen drive and i solved it connecting USB pen drive (or other deviced) to the OTG cable before connectig OTG cable to the phone.
Hope this will help.
Ciao.
I tell you my problem. I have a xperia sp Through That connect the USB OTG Cable UN look and it worked, but when I was a smoked did not seem right and my phone told me there had been extracted Security scam and then when I went to Connect again and do not recognize any usb ... That yes I can fix para DO THAT ... Much appreciate any solution
The phone has an option to browse USB storage..It must be supporting,otherwise what was it for?
