Hi all,
Im trying to have my sola respond to USB cables for charging only.
How do I do that?
Thanx in advance.
Xperia sola
Android 2.3.7
That's normal, as your internal storage is on MTP and there's no way to change this
unrelated topic, if you have some time please check this thread
Would also be able to do like the OP suggests with my xperia U 2.3.7 GB. Seem to get a different screen to earlier poster, with no "Auto connect in MSC". As soon as I connect my phone via USB to PC to charge the contents of the phone can be browsed in explorer. Would rather not have this happen at work to stop any admin being able to access it, and don't want to just use a mains charger. I'm sure I've seen other Android devices ask what to do on USB connection and present an option to only charge.
