How long it took for those who already updated to Jellybean? Mine stuck at "Initializing..." for about 3hours. Can someone help me?
By the way, I'm from Malaysia.
Problem solved!
Wong, try using Update Service. It works for me.
Here's the download link: http://www.sonymobile.com/gb/tools/update-service/
Good luck!
I'm facing the same issue, can some moderators please advice.
Hi Sim, if you're able to find the solution to it, please post it here. Thanks in advance.
Problem solved!
Good luck!
