Hey y'all,
I've got a Sony Ericsson Xperia Mini Pro that's working fine. Then i saw that there was a update! So i plug in my phone and press update on PC Companion. However, the 'Preparing the computer for the software update' takes pretty long.. It stalls at about 30 / 35 %. I already re-installed PC Companion. My internet connection is perfectly fine. Running Windows 7 and I never had this problem before.. Can someone help? I'd really like to update my phone!
Thanks!
try updating manually using this link
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Thanks man! It worked!
welcome
