Hi..
I Just now received 6.2.1.100 update through Sony PC Companion and i have ICS on my mobile. Can I update them.? Any bugs, fixes in the update?
tried tat and it works as of now
but don no when ll it stop
Don't is my advice - any update causes other features to be missing.
i know 3d sweep panoroma would be missed. but in future will this be available ? what are the other features that would be eliminated from jelly bean
i would say upgrade! its true you wont have 3d sweep panorama but you do have sweep panarama! plus i did not face any bugs after the update!
s update it ..
but first do a factory reset , then install the latest .100 update thro SUS(if not PCC but SUS is recommended) then aft installing the update, when u switch on the device do not touch it for 10-15 mins to allow it to get it settle down.. then again do a factory reset .. this clean installation helps ur firmware with bug free and lag free .. :smileylove:..
What about the white background in the call log and message app ? . Is it good ?
it depends on individuals .. i liked it..
Is there call lag problem, high usage of ram than ICS ? ? any other problem faced?
i didnt face call lag aft the update :smileyhappy:.. and aft factory reset the device is butter smooth:smileylaugh: .. the only problem i face is the notification problem:smileycry:
notification problem. u mean no sound during an incomin sms ? ?. If so, the same i face in ICS too. You need to boot to safe mode and restart your device for that to work.
