I am trying to update the latest version for my Xperia P and keep on getting the below error message, because of which I am not able to upgrade it. Tried it several times without no luck.
It fails in the 3rd step while trying to update it, I have checked the internet connection and its working fine without any issues.
you will have to wait for an hour or so and then press and hold power & volume up and see if that work, btw how did this happened? were you flashing a custom rom? unlocked the bootloader?
Sorry I am not sure about bootloader and custom rom....I was just updating using PC Companian and got a message saying it has updated successfully and clicked finish...after that I unplugged and tried to start it with no luck....
ok just follow my suggestion and then try to update your phone with SUS, another suggestion
on your PC create a new admin account on your PC > install SUS > restart your PC > after the 1hr of charging > try again with SUS > remember the phone has to be off with SUS
I have tried your suggestion with no luck now trying to update using SUS. But I am not able to take the backup of the data, vl contacts and other details will be lost?
everything will be lost, but a working phone w/o the data its better than a dead phone w/ all the data
oh....even the contacts will be lost....
what exactly would have happened?
if you backed them up with google then you can sync back
on your computer access your gmail > contacts
if you repair your phone with SUS the phone will be as new
Thanks finally I was able to switch on my mobile using SUS and even my data was available...I am very happy...but now small issue with the display where the center part is black and rest is white. Will attach the screenshot also.
I don't see the problem, the notification bar its black, you can take screenshots by pressing at the same time power & volume down
