how to update my xperia mini pro to android 4.0. while trying to update in pc companion, "pc companion was not able to connect to the phone.please disconnect and connect again". wat to do....plz help me......
Hi, I think what you meant is Android 2.3.4.
Not sure exactly what is the problem, did you try with another PC/Laptop? The other option is to use SE Update Service for the update.
Here's the download link, http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
