Hi dear friends
I noticed about new update in this forum and checked for it in my phone with update center , but it didn't show any update by now!
then I checked with pc companion several times that finally some hours ago it showed the new update for my C5303!
I downloaded the new update and tried to update my C5303 but when it shut down the phone to load the update , pc companion shows an error and tell that Update engine doesn't have software update available for your device!
Can anybody help me to solve this problem?
Thanks in advance
regards
Hi everyone .
I solved my problem with pc companion and finaly updated my C5303 with the last software update 12.1.A.1.205
It seems that the problem was the network problem cause I'm in Iran and we are under the sanctions... beause when I used an Antifilter proxy software and set the proxy in pc companion the software update downloaded again and instaled without any problem or error!
I request Sony to check this issu and if there are some problems for Iranian user to dwonload updates with pc companion via internet , please solve it ! cause Sony has sales representaters in Iran and we buy their products legaly !
thanks
look my ticket
i set the pc companion in english and problem was solved .
http://talk.sonymobile.com/t5/Xperia-SP/update-error-12-1-A-1-205/m-p/718273#U718273
tnaks for your help my friend. My pc companion language was in English by default and i don't know how I can to change the pc companion language!
Nothing! Only this!!!! ------>
thank u so much! I will try this and tell the resaults .
thanks again
@alexdon wrote:Use SUS:
http://www.sonymobile.com/gb/tools/update-service/
Wait some more,it should be available soon.
@alexdon wrote:Wait some more,it should be available soon.
I tried xperia update software but it says that my device has the latest software !
if there is no update for my C5303 why the Pc companion shows the 12.1.A.1.205 is available !!!???
