I Want some help with the instuctions of
http://unlockbootloader.sonymobile.com/instructions
I have install SDK .
But I cant continue on step 13 .
My pc dont ask for driver as step 13 says.
(On your computer, you will be asked for drivers.
Point to the usb_driver folder where you placed the android_winusb.inf-file,
and select the Android Boot loader Interface-file.)
Can anyone help me ????????
Sorry for my BAD English ,
Thanks in advance !!!!!!!!!!
me too, an help will be appreciate!!!
didn' t work, neather that. I can' t install my S1 fastboot device .. I point to the drivers but it doesn' t work.. Some help please
for anyone still stuck on unlocking bootloader, try using this method. I tried this, and it is working.
link downlod> http://www.ulozto.net/xdgy6dv/se-bootloader-unlocking-relocking-1-6-rar
your computer must be running net.framework v4 (google it) for this application to work.
hope this will help.
Hello there,
I tried the program but how do I know if my bootloader is successfuly unlocked ?
+ In order to use it do I have install drivers for my Fast boot devise or I just have to connect it in fastboot mode ?
If I need to install drivers please tell me where I can find them..
Thanks in advance
check it via dial pad : *#*#SERVICE#*#* (*#*#7378423#*#*)
yes, the phone need to connect in fastboot mode.the driver (S1 Fastboot Driver) also need to be installed.
check here how i installed the driver if your pc not install it automatic by putting the phone fastboot mode :http://talk.sonymobile.com/t5/Xperia-go/Xperia-Go-can-t-enter-fastboot-mode/m-p/475881
I tried what you said. It didn't work. It says "The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for 32-bit systems." I downloaded the sdk for 32-bit and tried using both, the sony and the default android_winusb.inf files. Also, I have the latest version of the platform-tools. My device is sony xperia sola. What should I do now?
