My contacts do not appear when i click on add recipient on messaging, they also dont come up in contatcs so i am unable to ring anyone but if i recieve a message or phone call of them their name and number appears. I would be grateful for any help! Also when i click the camera button it sometimes turns itself off!!! I will be grateful for any help, thank you!!
Don't worry about making it a question, it doesn't really matter.
It sounds like you need to have a look in Contacts, press Menu and then Contacts to View. The contacts are there in your phone by the sounds of it you just need to select the right option to view. Have a tick/untick in the various selections and see what you can find.
how do i make this a question!!??
..... Thank you that has now worked!!!!!
It would be great if I could have your software info.
Go to: Menu > Settings > About phone > Build number
The problem has been solved but what were you planning to do with the information!!?? :L
