LT18i - 4.1.B.0.431 - Regional Indonesia
How to remove application without locked bootloader and without rooting??
. Whatapps
. Astro FE free
. Lets golf HD
. Facebook for android
Please give user application full version not free version!!
you can't delete preloaded apps w/o rooting your phone.
if you have ICS you can do this
settings > apps > all > tap on an app > disable it
unrelated topic, if you have some time please check this thread
