Hello
Can someone please help me. I have a Sony Xperia U with Android version 4.0.4.
For the past 3 days I have the error message " system UI has stopped working" then my status bar dissapears for about 10 seconds, then it is back to normal.
This seems to be happening around 4-5 times a day, but just today I have noticed it happens every time I tap on a facebook notification within the status bar.
Does anyone know a quick fix for this without resetting my phone?
Thanks in advance
Do you experience the same problem if you start your phone in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
If the problem doesn't occur in safe mode, it's probably caused by some 3rd party application installed in your phone.
In normal, there is written Unfortunately system ui has stopped. And also in Safe mode, there is same message shown. Now plz solve my problem. If possible mail me;;
removed by alexdon
Download sony update service and repair.
does this thing need to be ON mobile. because my mob is not ON. It is repeatably restart after lock screen appear
No,to repair via SUS it must be off,but the battery should be over 60%.
I have window 8.1. Does this soft work in my window. Plz tell me
SUS does not include xperia U. now what i do?
Run in compatibility mode with windows 7.
But xperia u model is not there.
Compatibility mode win7 issue is after.
