Dear friends,
I uptodated my Xperia S to android 4.1.2
Howver, since then, my messaging has stopped working. & so does my email.
All the time I get this message on my screen: "Unfortunately, messaging has stopped. Ok."
And I can only check ok & nothing more.
Will you please help me?
Appreciate your care,
Neda
hello
I had the same problem and thanks to this forum I could find a solution and now my xperia s is running great thank you very much for the help
Dear Drinkgef,
Hope here we had an icon as 'Hopeful answer' too. Instead I chose the 'helpful one'
I became happy that the problem has been solved.
Cheers,
Neda
I got this mesage 'unfortunately messaging has stopped' just after i upgrade. I could not get red of this message. I did not backup my phone yet.
would should i do as 1.2.3 thanks,
Dear Jaroudphone,
Unfortunately the backup file for my phone did not work. A professional here told me that it is possible that a file has been corrupted in the restored files.
You might not have this problem, so it would be a good idea to use the beckup & restore item in your PC Companion.
After you have restored your files, see if u have this message again or not.
If you still have it, the same as mine, one of your files is corrupted.
This way I got use of the Factory Restore in the the 'Setting'. Again I lost all my data, but I could have my messaging.
Hope these explanations are useful.
Peace,
Neda
Dear All,
I am presently with this situation "unfortunately messaging has stopped "as i upgrade my XperiaS to 4.1.2 from 2.3.2 !:smileysilly:! Thanks to Nedane, for presenting a detailed discussion on this. While, i did not use any option mentioned above as i am little confusded to start with using "Backup and Restor with PC companion" or "Factory Restore in the MOBILE Setting "!!
As i never used any of these oprions before, what will happen to my installed applications,,they remain or will be deleted!!!:smileyhappy:
Please share some explanations for me!!!:smileywink:
Smiles :smileylaugh:,
Sri
Hi dear XperiaSri,
If you use 'factory restore' all your installed applications will be deleted. Those that you have installed. They original applications will remain of course.
Smiles back,
Neda
If I do the (factory reset) will the contacts be deleted??? i dont really care about the messages or the installed applications...Ive copied all my pictures and videos to the laptop, since I couldnt backup with the pc companion....
loosing contacts is my biggest concern
Dear Nedane,
I've already updated my phone.. and save my file in the computer.. im wondering wheither i have to download the software update provided in the Johan's link?
So I managed to backup the data on my brothers laptop using the PC companion. Made the factory reset and erased everything..Then I restored my data...and WOW THE MESSAGING STILL DOESN'T WORK???!!!! That's ridiculous
Updating my software is the biggest mistake Ive done... What should I do now??? I need an answer from a SONY personnel....
I'm the same, this is clearly a repeating problem with these phones. I have an Xperia J
I haven't recieved any texts since August 27th, what is the quickest way to fix this problem (even if that means resetting to Factory defaults)?
