Hello! I've saw a folders from old programs I have used, in OfficeSuite program, I want to know how can I get off from old programs files?
If these files are on the memory card (which they generally are) you can simply connect the handset to a PC and delete the unwanted files directly that way. Otherwise you can download a file manager application like Astro and then delete them via that application.
This file manager is great
IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
you should check My Phone Explorer
Hi!
Thanks for suggesting Astro File Manager, deleted some unwanted files from phone!
No problem, glad to help.
